by markgal251 Investigator
Call from Cyprus
Hi I am in Cyprus I have just topped up I have 50 minutes but can't even call any UK mobile or landlines It's say on the operator , I don't have enough credit . ??????? this 50 minutes has worked before in the past while I am in Cyprus . ??????
by Brilliant Contributor
Solution
Re: Call from Cyprus
Thank you for taking the time to reply @markgal251Smiley Happy
That message confirms your allowances have been applied onto the account without any problems and you should be able to make calls without any problems.
Could you go ahead and try a manual network search and connect to MTN please?
8 REPLIES 8
Hello @markgal251
Thank you for taking the time to visit the Community today. Smiley Happy
When you're dialling the UK numbers, are you replacing the 0 with either +44 or 0044?
Could you confirm, what network are you connected to? MTN or Voda-Cyta?
0044 and dropping the first number net work cyta voda
Can you preform a manual network search and try connecting to MTN if that network is available please?
Before you do try a manual network search, can you text either AL or BAL to 150 and tell me what the reply states?
Your current balance as of today 12:31 is £0.06. You have 50 minutes, 250 texts and 250MB remaining until 14/09/2017 for your £5 Everything Pack. Your last top up was £5.00 on 14/08/2017 at 06:30. For more info on your packs, add-ons or free boosts, go to MyEE. ee.co.uk/myee
Solution
Thank you That's done the trick logging on MTN 😀
Hi @markgal251
I'm delighted that @Inyourbox was able to help you get this sorted.
Enjoy the rest of your trip. 🙂
I'm glad to hear everything is resolved. Smiley Happy
I hope you have a good trip, Cyprus is truly wonderful! Smiley Happy
