by Quex101
Call barring
I am in Canada at the moment and cannot text or call out. I have tried removing the call barring but it errors out with a "cannot read data" message.
I have a note 8
I am on the Telus /EE network
I can receive calls and texts ok but cannot make them.
by Quex101
Re: Call barring
Hi.I tried all what you asked and there was no success! RegardsGrant
Sent from my Samsung Galaxy smartphone.
Re: Call barring
Hi @Quex101 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
