by joebuy712 Investigator
Bought note5 from USA. Can't get connected on EE. Followed instructions provided
Hi
I bought a note 5 from the USA. It came with instructions to connect to phone provider.
Moblie provider.
Access point name.
Got APN for EE from internet. But there is far more info to be entered on phone than internet provides.
MMSC?
MMS proxy?
MMS port?
Authentication type?
APN type?
and so on.
can you help please?
14 REPLIES 14
Re: Bought note5 from USA. Can't get connected on EE. Followed instructions prov
EE Employee
Hi @joebuy712 and welcome to the community.
Did you manage to sort the issue out after following the advice given by @Chris_B?
Many thanks,
Lee
Hi Chris
Didn't work.
Noticed some APN settings you had posted. Advice down to .APN type.
Problem is, i have 6 more settings after that
APN protocol
APN roaming protocol
Enable/disable APN
Bearer
Mobile virtual network operator type
Mobile virtual network operator value
EE Employee
Hi @joebuy712
Please do try and use the automatic setup guide:
http://setup-ee.wdsglobal.com/
Does this assist?
Cheers
Lee
hi
I cant receive texts.
EE Employee
Hi @joebuy712
Is your device showing any connection?
Many thanks,
Lee
no. emergency calls only
I would imagine that i will have to enable calls and texts first.
any suggestions
EE Employee
Hi @joebuy712
In the about phone menu within settings what is displayed in regards to phone model.
I'm wondering if the bands are compatible for the UK network.
Many thanks,
Lee
i asked b4 it was sent, if it would work here.
model no. SM-N920P
Baseband version N920PVS3DQJ1
sorry its PVP. Missed out P
phone wont even find EE network
EE Employee
Hi @joebuy712
Are you able to change the network mode to 2G/3G at all.
Many thanks,
Lee
