Highlighted
Blocking/barring outgoing
I need to barr a mobile number from being dialled off my phone and also to stop text messages being able to be send to a particular mobile number.
Can i have any instruction on how to do this please
Highlighted
Re: Blocking/barring outgoing
Hi @Jangal74
Just don’t call or text the number and then bar it under contacts. This is more a self-control issue.
It would have helped if you said what device you have.
Highlighted
Hi @Jangal74,
Which phone are you using?
Highlighted
Samaung s10Sent from my Samsung Galaxy smartphone.
Highlighted
Hi @Jangal74,
Please check out How do I Block Numbers on my Galaxy S10? over at Samsung Support.
Hope this helps. 🙂
