by Nicu19
Block Pixel 2 XL aboard.
Hi,I'm from Romania and I bought a second-hand Google Pixel 2 XL and is blocked on EE.What I can do to unlocked, I was trying to call but i can't do it from my Carrier.
Re: Block Pixel 2 XL aboard.
Hi @Nicu19
If it's blocked (lost or stolen) then it cannot be unblocked.
If it's just the carrier lock you want removing so you can use another sim then read EE guide which explains the process:
HOW DO I UNLOCK AN EE DEVICE TO USE WITH ANOTHER NETWORK?
by Nicu19
Hello thanks for the reply, I have called to that number and dont even rinning, nothings happend.
@Nicu19   That number will not work for you, you need to call this 44 7953 966 150
by Nicu19
Ok, I was called that number, but I dont understand very well what the lady saying, you can help me, what number do I need to press?
Hello there @Nicu19
If you speak to our unlocking team on 0800 956 6000 (select option 2, then option 4)
Thanks 🙂
