by BigFactHunt
Bixby freezing my phone in the command page continually saying no connection
Bixby just got even more useless and now freezes my phone in the command box
Re: Bixby freezing my phone in the command page continually saying no connecti
Hi
Do you use Bixby? If not then just disable it as I have done in my S8+
If you do then go into settings - apps management and clear the Bixby data/cache.
