by NK118
Betfair not loading?
Are you having issue with betfair sites/apps? Nothing loading up but works fine on my home broadband (vodafone) and mobile data ( tesco mobile)
MIFI working fine last few weeks just last 24 hours not working on betfair.
Re: Betfair not loading?
Hi @NK118
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Hi @NK118.
Welcome to the community 🙂
Have you been able to log into Betfair after changing your content lock settings in your My EE Account?
Got any tips? 😉
Jon
by NK118
Hi i have been able to log in since changing setting but does not load any markets to bet on, so have to switch to other internet sources to place bets
Hi @Mk118,
Have you tried leaving feedback in the app store to see if the developer can help?
