by Helen32
Best phone to upgrade to
What would be the best Android to upgrade to
Re: Best phone to upgrade to
Hi @Helen32
It depends on your usage, requirements and budget.
The new Huawei P20 Pro has a great camera and a great deal on free headphones at the moment.
The Galaxy S9 and S9+ is as popular as ever and Samsung deliver amazing screen and quality overall. The plus has the bigger screen and twin cameras.
Then you have the new Song Xperia XZ2 (pre order) and the Google Pixel 2 and Pixel 2 XL.
These are your higher end phones but I would suggest you go into store and get a feel, or do you stick with a certain brand maybe?
Hi @Helen32
Thanks for joining our community 🙂
I can see that you've had some fantastic help from @Northerner
I hope that the support given helps you make the right choice for you.
Come back and let us know what you get.
Cheers
Richard
by uvarvu Established Contributor
From a software perspective there are a few interesting features coming in Android P which no phone but the Pixel will see this year.
