by Roz_Lake66 Investigator
'Bar voice over wifi calls add on' what is this please?
Re: 'Bar voice over wifi calls add on' what is this please?
Hi @Roz_Lake66,
Welcome to the EE Community.
It means WiFi calling isn't enabled on your account.
Have you recently reported any problems with Customer Care?
I have tried to actuvate Wi-Fi calling several times and spoken to customer services a long time ago.
I just looked at my log ins and found this one as active.
I have now turned it off as an add on, dies this mean that this add on was preventing Wi-Fi calling?
I did not add it myself,  it looked like it was a standard one added.
It could have been @Roz_Lake66
Is your WiFi Calling now working?
The change I made won't be activated until 17 April.
How do you know if Wi-Fi call is working if you have a network signal?
Thanks for your help.
Hi @Roz_Lake66,
You can check by activating Airplane mode before turning on WiFi.
