Highlighted
by Investigator
Apple Music works OK on my Sony ZX1 Compact but it won't stream to car audio
When I connect my phone to my car's audio system with Bluetooth the audio system displays the selected track - but there is no sound. The connection works fine for phone calls
Highlighted
by Investigator
Solution
Re: Apple Music works OK on my Sony ZX1 Compact but it won't stream to car audio
Chris,
I tried playing the MP3 files resident on my Xperia - didn't work, so I contacted SONY help chatline. Their recommendation was:- Find and tap Settings > Network & Internet.
Tap the menu button (three vertical dots) > Network settings reset > RESET SETTINGS.
I then had to re-assign network password for my web connection nd re-pair my phone connection to the Citroen,
It worked!!!!
9 REPLIES 9
Highlighted
Hi @Steamboat
Welcome to the community.
We'll do our best to help.
Does your Apple Music work when connected to other Bluetooth devices?
Do other devices play music when connected to your car via Bluetooth?
Highlighted
by Investigator
Thanks for your reply Chris. I don't have any Bluetooth devices to connect with. Up to now I have only used a USB stick to play music on my car's audio - but the car's Bluetooth connection works fine with telephone calls.
Highlighted
Hi there @Steamboat
Thanks for coming back to us.
The terms and conditions for Apple Music do advise;
The subscription provides you with access to digital music and other related content (the Service) on the App and allows you to stream Apple Music to a single device at a time.
Has this worked previously for you?
Thanks, Leanne.
Highlighted
@Steamboat   Can you car stereo  actually receive music that’s Bluetooth to it ? you need to look at your car stereo manual for this.  Just because it works for phone calls it doesn’t mean it can work for music as this uses the A2DP. (Advanced Audio Distribution Profile)
Highlighted
by Investigator
Thanks for your response. I have not used Apple music before - it came as an offer with my EE contract - so I thought I would try it. I am not sure what you are getting at about the Apple T&Cs. As I see it I stream Apple Music to my phone. That is the single device. Connecting the phone to the car's audio by bluetooth to permit better listening is surely no breach of the T&Cs??
Highlighted
by Investigator
Chris, The car I am using is a 2-year-old Citroen  C4 Picasso. The manual advises it allows bluetooth to stream audio files from a phone. It goes on to say it will only play files with .wma, .aac, .flac, .ogg and .mp3 extension with a bit rate of between 32Kbps and 320Kbps. I have no idea what file extension Apple Music uses. I think I will try copying some MP3 fie to my phone via sony Xperia Companion and see if they stream OK. I will let you know how I get on.
Highlighted
What happens when you try to play another file with audio, @Steamboat?
Like a recorded video, sound clip or a video from a site like YouTube. Does the audio come through?
Highlighted
by Investigator
Solution
Chris,
It worked!!!!
Highlighted
Magic, @Steamboat.
I'm glad they were able to help you get sorted. 😄
Enjoy your Apple Music. 🙂
