by Iangodden17 Investigator
Any one had any issues with Samsung
Looking to get either the Samsung s8 of iPhone 7 anyone got any ideas
7 REPLIES 7
Re: Any one had any issues with Samsung
@Iangodden17   It's what you prefer and if you ask any one you'll always get a biased opinion.
I am thinking about ease of use
Sent from Yahoo Mail on Android
by Profile closed
Not applicable
All I'm going to say is if you want your O/S updates as soon as they are released, then Apple wins every single time (on any iPhone purchased from anywhere as well).
@Iangodden17  Have you ever had an iPhone ?  If you have had one before it's not changed.   One of the lads I work with has changed to a s7 from an iPhone and he says that an iPhone is so much better on ease of use. Go to your local EE store and try the devices yourself and see what you prefer.
Thanks I have a 6S as work phone it's a bit large not sure I like it got to get used to after using my h t c one m9
by Brilliant Contributor
The S8 is around same size as the iPhone.
The S8 Plus is much larger.
If size is an issue then go by that
I prefer Samsung as your not trapped of what you can do.
Yes updates is an issue so if you can get straight from Samsung.
@BrendonH   What can you do that can not be done on a iPhone lthat makes you think your trapped with an iPhone ?
Calls
texts
email
take photos
mms
Various apps from the App Store/play store
sat mav
list goes on.
@Iangodden17  and that's my point of my first comment,  It's your choice and what you prefer.   I'm a iPhone user since the original iPhone  and I've purchased a few apple products along the way because I like the way that they integrate with each other but that's just me on what I want and what I prefer.
