by Sean9090 Investigator
Annual upgrade from Note 8
Hello
I have just started a new 2 year contract with the Samsung Galaxy Note 8 with EE, what I would like to know is how do I go about seting up an annual upgrade plan? Do I enquire in store or over the phone?
Re: Annual upgrade from Note 8
What plan are you on as it's automatic depending on your plan.
 £63 per month Unlimited Calls Texts 25gb data and some aditional add-ones like BT sports and Apple Music
by Profile closed
Not applicable
The £62.99 plan doesn't come with an annual upgrade unfortunately, only the 40Gb £72.99 plan includes the annual upgrade.
You would have to ask EE to move up to this plan in order to get an annual upgrade included.
Hi @Sean9090 🙂
I've had a look at this and it seems that for the Note8, @Profile closed is correct.
Have a chat with our customer service team and they will help you change to that plan.
Find out more information about annual upgrades >
