by beddauboy Investigator
Android nougat
Can u tell me when Android nougat is going to be released for Galaxy S 6
by Ace Contributor
Re: Android nougat
@beddauboy
 EE don't provide firmware update and release dates but when one is available your phone will tell you and
You will get a notification to download new updates.
Many Thanks
by Skilled Contributor
Skilled Contributor
Re: Android nougat
Did you get your handset direct from EE or Carphone Warhouse etc...??
BTU unbranded has been released today.  Typically handsets from CPW and 3rd party sellers will have this firmware.
EE firmware is EVR and is yet to appear.
Dial *#1234# and post the information so we can tell you.  Alternately if you check for updates today and you are on BTU you'll get Nougat.. 🙂
