by swannyboy79
Android issue with P9
 I tried to manually update my phone to emui 5.0 and Android 7.0, it didn't work and I had to do a hard restore, so now I have it running but it is at 3.1 for emui and Android 5.1 beta, the model number was Eva-l09 now it's at A168-L09, how can I get my phone back to the version it was at, tried the updates on emui, in settings and hi care, any help would be greatly appreciated thank you
Re: Android issue with P9
So you have tried to install a rom which has failed?
by swannyboy79
Basically yes, so I done a hard restore
You should check out XDA developers for help as you need to download the most recent rom (EU or EE one) and flash that one. The one you tried to install was a leaked beta.
