by normalsnail
New Member
Android 8.1 stable update for Nokia 8
I believe as Android updates are subjected to carrier approval, EE is holding up the recent Android 8.1 stable update for the Nokia 8. It has been released for 10 days, but EE customers are the only one that have not received it yet. So if EE is unaware of this situation, it would be good to work on it, as previous updates have been released by EE promptly and it would be unfortunate to ruin that reputation. Thank you!
by Brilliant Contributor
Re: Android 8.1 stable update for Nokia 8
I believe the Nokia phones are using stock android which is  it subjected to network approval.
