by Kmach1 Investigator
Android 7
When are EE rolling Android 7 out to s6 ?
Very poor will be moving back to Vodafone.
by Brilliant Contributor
Solution
Re: Android 7
@Kmach1, EE will only roll out updates once they are sure that there is no conflict with software EE have installed on their phones and it is not going to cause any problems, we have no idea, as EE do not let anyone know until they release updates, not poor, but making sure there is no backlash, if they were to release it too soon.
Solution
Re: Android 7
by Ace Contributor
Re: Android 7
Who marks these as solutions?
The real answer is EE don't really care as they have moved onto newer phones. It may come eventually, but there's no incentive for them to upgrade it or provide security updates.
Android/Google need to fix this and hopefully Android O will go some way to do this, but don't expect that any time soon either!
by Skilled Contributor
Skilled Contributor
Re: Android 7
EE have never cared how old your handset is.  They have always been the worst with updates.  Best thing you can do is flash a generic unbranded firmware as soon as you get a handset from EE.  You'll get the updates as soon as the manufacturer releases them then.
