by isneddersi
Android 7.0 Nougat on Samsung s7 Edge
Hello
I am looking to find out when I will recieve the 7.0 update on my s7 edge.
Any news of a date of release?
9 REPLIES 9
Re: Android 7.0 Nougat on Samsung s7 Edge
Your phone will tell you when your upgrade is available.  I don't believe its fully available until the 17/1/17 but those who are on the beta test receive the update first.
If I was you then I would install BTU firmware via Sams mobile as you can still use the WIFI calling service and you receive any updates first.
Thanks,
by chipxtreme Valued Contributor
Valued Contributor
l would say probably shortly after the S8 is out so i'll probably never see it on my phone but i'm enjoying 7.1.1 on my Pixel C tablet.
by neils31 Established Contributor
by ynot68 Established Contributor
Needs to hurry up or else i will sacrifice VoLTE and install BTU Smiley Happy
by MDeaks
New Member
This was 2 weeks ago, so clearly not......
by baigsu Investigator
As of today (14th) I was told working on it and 4-6 weeks to go.  Longer if issues found.  I asked why so long (O2 already rolled for S7) and apparently something to do with that useless wi-fi calling function which is specific to EEand the cause of the delay
by Star Contributor
Star Contributor
The calls of wifi was an "issue" in the last OS update.  I find it very very hard to beleive the fix or change that was put in place to allow it to work with Marshmallow doesn't work with Nougat.
Samsung have the feature in the device so it must be an EE specific setting or change which is fine but if its been done once why is it so hard now?
I strongly beleive this is an excuse and no one has been able to provide information to prove otherwise.
But please please if you have any information on the changes in Nougat that would reinstate the issues of the wifi calling please let the EE customers know.
by Darren-45
This update should be out now come on this 6.1 as screwed my phone up
by Joshua111 Established Contributor
my s7 edge has now received the update
