by Skilled Contributor
Skilled Contributor
Android 10 rolling out to EE Samsung Galaxy S9's
Hi
I've just received a large OTA update to  upgrade my EE Galaxy S9 to G960FXXU7DTAA which is the first release of Android 10 (Q) for the S9.
So if you go to Settings.. Updates and ask yours to check, you might get yours upgraded too (if you want to!). This is an EE supplied phone - not sure about all the CPW or generic phones yet.
Peter
by Ace Contributor
Re: Android 10 rolling out to EE Samsung Galaxy S9's
Hi @whiskerp
The BTU version received it last week.
Thanks,
David.
by AuroraLight19 Established Contributor
How is this right?
EE rolling out android 10 to the S9 released a couple years ago yet not to the p30 Pro which is Huawei current flagship and less than 12 month old!
by Brilliant Contributor
Because Samsung has built a firmware which has been approved by EE, Huawei hasn't. They are different builds with different UI so you can't compare.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Skilled Contributor
Its Samsung's doing, not EE's directly. Huawei seem to lag behind.
Peter
by zeeuk Established Contributor
How does that explain the fact that customers on Three O2 Vodafone and Virgin plus sim free phones received the updates last year? How is this Huawei fault?
