by LN080281
Am I able to change my phone number?
by Ace Contributor
Re: Am I able to change my phone number?
I think it would be cheaper, if you get a PAYG SIM card from another network, and then transfer the number to EE.
Otherwise, EE would charge you around £35 admin fee to change your number.
W
Hi @LN080281
Welcome to the community. 🙂
Could I ask why you're looking to change your number?
If it's due to nuisance calls, we have some fantastic information on our stopping unwanted calls help and support page.
by LN080281
Morning.
Yes it's call from an ex partner
Get Outlook for Android
Ah, OK @LN080281
It may be worth contacting our customer service team.
They'll be able to change your number for you.
Hope you get it sorted and have a lovely Christmas. 🙂
