by tigerbob
Alcatel Pixi 3.5
Does the online order come with a sim card
Solution
Re: Alcatel Pixi 3.5
@tigerbob  If this is an upgrade and your current sim doesn't fit you'll get a new SIM card.   If you have purchased this as a payg then you'll get a SIM card with it.
Solution
