by Akerr Established Contributor
Advice about sms hijacking after receiving a text from ee
Hi there I'm just looking for some advice, I have an app on my android phone called device monitor,  and today i received a notification from it, warning me of sms hijacking straight after I received a text message from ee,  I'm just wwonderin what exactly does this mean and how do i prevent it from happening again, is it something i should be concerned aboutScreenshot_20180419-151835.png
by Ace Contributor
Re: Advice about sms hijacking after receiving a text from ee
I am not an Android user, but I think it would be helpful if you could leave the make and model of the phone, so that other knowledgable members of the community will be able to assist you.
W
Hi @Akerr,
Welcome back to the community.
That's a genuine text from EE. It must be an error with the device monitor app you are using.
