by loonyy22 Investigator
About to get a EE G930F S7. is the firmware update to oreo 8 easily available?
If i should need it or to do it, is this all sorted now from EE OTA or do i have to go through sammobile and the odin way to get oreo 8?
thanks
Re: About to get a EE G930F S7. is the firmware update to oreo 8 easily availabl
@loonyy22  Depending on where you got the device from will depend on where the update comes from but your device will inform you if there is an update for your device.
ok does this tell you?
SM-G905F32GBEVEA
mmm i think not, ill have to wait till it arrives and get the numbers.
Post what dialling *#1234# returns.
