by Coltrans Investigator
APN settings for Doogee T5 Android 6 phone
I'm having problems setting up mobile data on my Doogee T5 phone. I've tried all the various settings I've found in the community and elsewhere but nothing has worked so far. I'm on an EE contract and have set mobile data to the EE SIM (it's a duel-SIM phone).
Many thanks in advance.
Solution
Re: APN settings for Doogee T5 Android 6 phone
Thanks @Coltrans
Are you able to try the SIM in another phone and see if this works ok?
Thanks, Leanne 🙂
13 REPLIES 13
@Coltrans  Try the SIM card in the other sim slot.
Many thanks for that but I've tried it and it still doesn't work.
I have found 2 sets of APN settings, one with a user name and password and one without. Which one should I be using?
EE Employee
Hi @Coltrans
Please use the following APN:
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
Many thanks,
Lee
Thanks for the help, but it's still not working.
In addition to the entries in your list I have:
APN protocol and APN roaming protocol with the options IPv4, IPv6 and IPv4/IPv6. Any idea which I should choose?
There is no entry for APN Type.
Any other suggestions?
Thanks.
Hello @Coltrans
Can you select IPv4/IPv6 and let us know if this works.
Thanks 🙂
No, that makes no difference.
I don't think I'm doing something stupid - but it's possible.
Many thanks for your help.
Hi @Coltrans
What happens when you try and connect to the internet?
Thanks 🙂
I get a message saying I'm offline. I've tried variously Opera, Chrome and other apps but they all say much the same.
I have (most of the time) an "E" in the staus bar - occasionally "3G" - if that means anything.
Signal strength is variable here (but better than any other network). I've been outside to test but still get the same result.
Data roaming is definitely on and registered to the EE SIM.
Thanks.
Thanks @Coltrans.
Are you in the UK at the moment?
Do texts and calls work ok for you?
Thanks, Leanne 🙂
Yes, I'm in the UK and texts and calls work.
Thanks!
Solution
Thanks @Coltrans
Thanks, Leanne 🙂
The solution was in fact to go into "Data usage" and turn on mobile data on the relevant SIM there. Apparently this applies to dual-SIM phones - and I found it on the GiffGaff forum!
Thanks for all your help!
EE Employee
Hi @Coltrans
Glad you are now sorted.
Many thanks,
Lee
