by Nizpatel
4G calling on non EE Samsung Galaxy S9
Hi
I was using a Samsung Galaxy S9 with EE firmware and the 4G calling worked a treat. I switched handsets to the same model but with Vodafone firmware and the 4G calling doesn't work. I know EE does not support 4G calling if the handset was not purchased from them. But is there any way I can flash the Vodafone branded S9 with EE firmware?
Re: 4G calling on non EE Samsung Galaxy S9
@Nizpatel  The s9 will support 4G calling if not from EE but your issue being the Vodaphine software on the device.  You can flash EE firmware to it but you’ll need to google this as you’ll not get a step by step guide here as no one here will accept the responsibility if you get this wrong.
by Nizpatel
Thank you for the quick response.
I am in the process of downloading the firmware now. Do you know whether I would still receive regular software updates from Samsung?
