by FT1708 Investigator
2 Questions About Harrier Mini And Storage
Hi All I Currently Have An EE Harrier Mini I Had 2 Questions About It Question 1 Is: Can It Be Upgraded From 5.1.1 (Lollipop)  To Android OS 6.0 (Marshmallow) I Was Just Asking This Because I Cant Seem To Find The Answer That I Am Looking For And The 2nd Question Is: Is It Possible To Expand The Storage From A Micro SD Card? If So Whats The Expandable Memory It Can Go To Via Micro SD? If Anyone Can Reply ASAP I Would Be Very Grateful For An Answer Thank You Very Much. 🙂
- FT1708
by Ace Contributor
Re: 2 Questions About Harrier Mini And Storage
HI
@FT1708
1: i dont think ee going to ugarde its software.
2: it can take up to 32 GB Micro sd card
Okay Thanks For Your Reply 🙂
- FT1708
