by rhain
New Member
14 digit sim serial number
Hi, I'm having a problem in regards to being unable to find the last 2 digits of the sim serial code. I followed the guide offered in the solution for an android phone however there aren't any numbers listed under ICCID.
Could you please help?
EE Employee
Re: 14 digit sim serial number
Hi and welcome to the Community @rhain
So I can try and assist, please may I know the following:
  • Where the SIM card is from?
  • Is it for a replacement, upgrade or new connection?
  • Do you still have the letter it was attached to?
Many thanks,
Lee
