by Jaytheguvna Investigator
Αny issues with the one plus 7 pro?
Has anyone had to return there one plus 7 pro because of faults?
by Star Contributor
Star Contributor
Re: Αny issues with the one plus 7 pro?
Hi Jaytheguvna,
What kind of problems are you experiencing with your OnePlus 7 Pro?
I have not experienced any issues with mine.
Thanks,
Peter
Was just wondering before I went ahead with the upgrade, as there have been a few reports of it shutting down and not been able to turn on again. They have had to do numerous things to get it working again.
Sent from my iPad
