by martinbenson198 Investigator
hs eobc vs normal
When looking at buying a data add on for the month there is the option to buy 1gb hs eobc or 1gb add-on.
both have the same size, both last 30 days, but one is 4.99 the other 7.99.
Can anyone tell me the difference between the two?
by Profile closed
Not applicable
Solution
Re: hs eobc vs normal
I'm guessing the more expensive one wont be speed capped, whereas the cheaper one will be capped at a maximum speed of 60 Mbps down.
hs = high speed?
10 REPLIES 10
by Profile closed
Not applicable
Solution
hs = high speed?
Hi @martinbenson198
Is this for a phone or mobile broadband device?
Also, are you on pay monthly or pay as you go?
phone and pay monthly
EE Employee
Hi @Martinbenson
@Profile closed is indeed correct, one is high speed and the other is standard speeds.
They both last until the end of the billing cycle.
Many thanks,
Lee
what is the download speeds for high speed and normal speed?
EE Employee
Hi @martinbenson198
Please see the post above from @Profile closed.
Many thanks,
Lee
by UnwantedUsernam
New Member
So what does HS EOBC actually stand for EE? and why have you made it so unclear?
Hi @UnwantedUsernam
Could you send over a screenshot of your phone with this add-on on the screen please?
Chris 🙂
by thomagr
New Member
Typically:
Screen Shot 2019-09-20 at 7.33.31 AM.pngAdd-On on website.
It is true that is really unclear. What are the respective speed for non-HS vs. HS? A bit of clarity would help on this page.
Also looks like uploading picture in a thread is broken.
Hi @thomagr.
Welcome to the community.
The speed you get will depend on the area that you're in, have you bought one of the add-ons?
Jon
