by Vetts24
New Member
add ons
I am of to Vegas in October and need to know what add ons I need please
Solution
Re: add ons
Hi @Vetts24
Ooh how exciting. 🙂
If you've taken out an EE Max plan after May 2017, or on one of our new Smart plans with the Roam Further swappable, you'll be able to use your normal allowances in the USA.
If you'd like to switch to one of those Smart plans, our Mobile Care team will be able to sort that out for you.
Otherwise, you can find the costs and add-ons for the USA on our Roaming Tool.
Make sure you text ROAMING to 150 or check that roaming is set up in your My EE account before you go.
Viva Las Vegas! 😎✈️🌵
Solution
Re: add ons
Hi @Vetts24
Ooh how exciting. 🙂
