by Polox20
New Member
Upgrade
Hi there I’ve set up a new plan £43 then I get a email to say I’ve had 2 x 1g for £4.99 each how do I remove these thanks
Solution
Re: Upgrade
@Polox20 : If it's a recurring UK/EU data add-on, text STOP 1GB ADD-ON to 150 for the 1GB add-on. If nec. try it twice.
Solution
Re: Upgrade
Recent solutions
