by Roxannepp Investigator
Trying to add travel data plan SPAIN but text won't send
hi
im in Spain right now, trying to add abroad data plan add in but the message won't send!
any help much appreciated.
14 REPLIES 14
Re: Trying to add travel data plan SPAIN but text won't send
Hello @Roxannepp
Thank you for coming to community all the way from the Mediterranean 🙂
Hope you are enjoying Spain and the weather is gorgeous 🙂
Did you activate Roaming before you went away?
If not, then for a little sun shine reading you may want to have a look at our Roaming with EE - What to do if you're having problems abroad post.
Also, I wanted to give you some of our pricing information for Spain if you have time to look at it.
Let us all know if you get sorted
Cheers
Richard
by connor1
I also have the same problem in Holland can't contact the 150 number for data and I really need it
Hello @connor1
Thank you for coming to community all the way from Holland:)
Hope you are enjoying your time away?
Did you activate Roaming before you went abroad?
If not, then you may want to have a look at our Roaming with EE - What to do if you're having problems abroad post.
Also, I wanted to give you some of our pricing information for the Netherlands if you have time to look at it.
Cheers
Richard
by connor1
I activated roaming as soon as soon as I got here I know the package I wish for it asked me to text travel to 150 but when I try the message fails
Are you able to turn your 4G off and then try again?
If this doesn't work @connor1 then please call customer services and they will help you.
Thank you
Richard
Hi Richard,
Thanks for the update.
I maanged to add the data package via your website but I am still havign the sam eissue with text messages.
Have done all the fixes on the link you sent - send SMS and manual network search and still no joy.
Any more ideas?
Thank you.
Activated roaming on what, your phone or on your MyEE a/c? You're supposed to enable it before you leave by texting ROAMING to 150.
EE Employee
Hi @Roxannepp
Are you able to make calls?
Many thanks,
Lee
Yes - calls have gon through to UK numbers.
Thank you
EE Employee
Hi @Roxannepp
What type of phone do you have and is it only texts you are now having issues with?
Many thanks,
Lee
Hi Lee
I have an iphone - I think its a 4?
I am able to make calls and receive texts - the only issue is not being able to send them.
Roxanne
EE Employee
Hi @Roxannepp
Please can I get you to turn off imessage within the messaging menu to see if that helps.
Many thanks,
Lee
Hi Lee,
Yes I've already tried this from the previous suggestions.
Have done different carriers with imessage on and off.
EE Employee
Hi @Roxannepp
As the suggestions have not worked, please pop to the live chat link.
This can be found in your Private Messages.
Our customer service team will be able to assist with your issue.
The link will be active from now till 8pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
