Highlighted
Plan Add on Accesory
Hi there,
According to the list of add to plans there is a 43inch LG TV.
Please can you tell me what the model number is as there is absolutely no information on it!
Kind regards
Deon
Highlighted
Solution
Re: Plan Add on Accesory
Good Afternoon @Deon3366
This is the 43UM71 4K 2019 model
Katie 🙂
Highlighted
by Established Contributor
I'm not sure the model sorry but I got the samsung 43inch 4k tv its brilliant
Highlighted
Solution
Katie 🙂
Highlighted
Hi @Katie_B,
Thank you very much.
Kind regards
Deon
