by Martinwilmot
Not received bt sport PIN
I have attempted to get the PIN for the bt sport app on a few occassions and still no text is received. I recently ported my number over from o2 to ee.
Re: Not received bt sport PIN
Good Morning @Martinwilmot
Is this the PIN for first time set up?
I would recommend speaking with our technical care team who can help retrieve the PIN.
Thanks,
Katie 🙂
by Martinwilmot
It is sorted now. I disconnected from any wifi and used the 4G to send and receive the messages and this worked straight away.
Thanks for the update @Martinwilmot
Glad you got it sorted. Smiley Happy
