by cupcake1978 Established Contributor
Is it possible to buy £5 top up vouchers
Hi I am running out of data oo my £10 data package and waw wondering if it is possible to buy a £5 top up voucher so I can add on 500mbs for 30 days .
Is there a minimum amount for top up vouchers?
Regards
by Star Contributor
Star Contributor
Re: Is it possible to buy £5 top up vouchers
You should be able to buy a £5 top up voucher from a local retailer with the top-up logo and then use that to add the credit to your account to buy the addon.
EE Employee
Hi @cupcake1978 and welcome to the community.
Hopefully, the information provided by @Peter_C has cleared a few things up for you.
Many thanks,
Lee
