by JDsports
New Member
I am using the travel data 500mb for £4 in USA, when does the data restart is it
I am using the travel data 500mb for £4 in USA, when does the data restart is it midnight USA time or midnight U.K. Time
by Brilliant Contributor
Solution
Re: I am using the travel data 500mb for £4 in USA, when does the data restart i
Hi @JDsports it is midnight Uk time
Solution
