by RockA
New Member
How to remove fixed add on
Re: How to remove fixed add on
Hello @RockA
Thanks for coming here 🙂
What add-on do you have on your account that you would like to remove?
If this is a data add-on, you can cancel the recurring data add-on by text, if you text STOP 1GB ADD-ON or STOP 2GB ADD-ON to 150, if you have purchased a higher data add-on just add the GB amount you would like to remove.
Let me know if you have any questions.
Leanne 🙂
