by Jordan9888
How do I stop a add on
Solution
Re: How do I stop a add on
Text STOP 1GB ADD-ON to 150 for the 1GB add-on.
Hi @Jordan9888
Welcome to the community. 🙂
Which add-on is it? Can you remove it in your My EE account?
by Jordan9888
Hello it is the recurring add on of additional 1gb data I can’t seem to remove it from the EE app
Sent from my iPhone
Ah, OK.  Thanks, @Jordan9888
Our Mobile Care team will be able to remove the add-on for you. I'd definitely recommend getting in touch with them.
Chris 🙂
Solution
by Jordan9888
Thanks it worked👌🏻
Sent from my iPhone
