by croninsfc
How do I remove an add on
So I go to my list of add-ons but the button doesn’t seem to allow it to be removed!
Does this mean I have to contact customer service to get them to remove it?
by croninsfc
Solution
Re: How do I remove an add on
it was a removable add-on and I found the answer in another thread. Simply had to text “STOP 1GB ADD-ON” to 150.
Cheers,
Steve
Hi @croninsfc
Welcome to the community.
If it's a fixed add-on, our Mobile Care team may need to remove from our end.
I recommend getting in touch on 150 so that they can help you with that.
by croninsfc
Solution
Cheers,
Steve
Thanks for letting us know, @croninsfc. 😄
