by Shiv68
New Member
How do I get code to go on bt sport
Solution
Re: How do I get code to go on bt sport
@Shiv68   You need to text SPORT to 150 and wait for the reply message and or use THIS
8 REPLIES 8
Solution
by Tolvern Investigator
I am trying to get a pin for but sports I put all the relevant information ie mobile number and postcode and then it asks for a pin which they will send you but I am not receiving the text as I am on a data only plan,  how else can I register bt sports
@Tolvern : Even on a data plan you can still receive texts for free.
But have you read the Solution above?
Hi @Tolvern.
Welcome to the community.
What device are you using your SIM card in?
Jon
I am using an iPad air
Thanks @Tolvern.
Can you try putting the SIM card in a phone to receive the text if you're not getting it on your iPad?
Jon
I have tried a different phone and still not receiving any text messages
Thanks @Tolvern.
I'd recommend contacting our Customer Care team who will be able to help you get your account set up manually.
Jon
