by Mattyshaw
New Member
How do I cancel My reoccurring data add on
Solution
Re: How do I cancel My reoccurring data add on
Solution
by Ace Contributor
Please follow the below instructions, depending on the amount of data your add-on is for:
You need to send a text to 150 with the following:
For a 1GB recurring add-on send the text STOP 1GB ADD-ON
2GB recurring add-on send the text STOP 2GB ADD-ON
5GB recurring add-on send the text STOP 5GB ADD-ON
10GB recurring add-on send the text  STOP 10GB ADD-ON
20GB recurring add-on send the text STOP 20GB ADD-ON
