Highlighted
by Investigator
Can not log in to bt sport on my amazon fire stick
Can not log in to BT sport on my amazon fire stick
6 REPLIES 6
Highlighted
Re: Can not log in to bt sport on my amazon fire stick
@JustJason007   Do you have an account with BT sport ?  As the offer from EE is not for watching on the fire stick
look HERE to see what devices you can use EEs offer with.
Highlighted
by Ace Contributor
Hi @JustJason007 and @Chris_B BT Sports will not work on fire TV stick as that that required Google play services.
I Hope that will help.
Highlighted
@tahirmian   That’s what I said
As the offer from EE is not for watching on the fire stick ”
But if @JustJason007  has setup an account directly with BT sport they can watch on the fire stick.  Hence my  opening reply.
Highlighted
by Ace Contributor
But BT Sport App is Not Available on Fire TV Stick that what I mean.
Highlighted
@tahirmian it might not be officially available but there are ways of installing it on the fire stick if you know how.
Highlighted
by Ace Contributor
I know @Chris_B  I try that my self that app is not compatible with fire TV stick same as sky go.
