by Helenloaten
Can I view BT sports via WIFI rather than using my data allowance?
EE Employee
Solution
Re: Can I view BT sports via WIFI rather than using my data allowance?
Hi @Helenloaten and welcome to the Community.
The Device will need to have an EE SIM card in for it to verify the app.
Customers can stream the BT Sport app over WiFi as well as the EE network.
The BT Sport app automatically defaults to WiFi and will try to use WiFi wherever possible.
When you try to access the BT Sport app when you're out and about, it will notify you and take you to your settings where you can switch mobile data on, if you enable mobile data, you will then be able to stream over the EE network.
Details regarding the promotion can be found on our dedicated BT Sports Page.
Hope this helps,
Lee
No you need to use the sim to verify your EE account.
Thanks,
EE Employee
Solution
Hope this helps,
Lee
by Helenloaten
Thanks Lee, really helpful.
EE Employee
No problems @Helenloaten
Do enjoy the BT sport app, I use mine mainly for the Champions League, Europa League and the UFC.
What will you be using yours for? 🙂
Many thanks,
Lee
