by rdon
Bt add on gone wrong
Been waiting over 48hrs to get bt sports app to work as part of my plan. Was told 24hrs.... do I really get it as part of the plan? It does say free but I doubt it’ll ever work!! Not good ee
Solution
Re: Bt add on gone wrong
Good Morning @rdon.
Welcome to the community.
It's great that you're looking to use the BT Sport app, and yes, you do get it as part of your plan when you're on a Max Plan, or a free trial on our other plans Smiley Happy
This error usually means there is something wrong with the set up, potentially that your email address hasn't worked or has maybe been used before.
I'd recommend contacting out Tech Gurus who will be able to get this sorted for you, hopefully in time for the football today!
Jon
@rdon  Have you text SPORT to 150 yet ?
by rdon
Yes all done. Just keep getting the message now: “Your service should be up and running within 24 hours. You may see an 'ID003' error message until your account is fully activated – please ignore the 'activate' button if this occurs. Please contact EE on 07953966250 if you are still seeing this message after 24 hours.”
Solution
Good Morning @rdon.
Jon
