by Marka2723 Investigator
Best add-on for Canada
 Hi, I'm going to Canada next month, what's the best add-on? Thank you, Mark
Solution
Re: Best add-on for Canada
Hi there @Marka2723
Welcome to the community.
If you have a Max Plan taken after 10th May 2017, you can use your minutes, texts and data in 53 destinations including Canada.
You can check your plan in your My EE app.
If you don't have a Max plan follow @Chris_B's great advice for charges and add-ons for Canada.
Before you go, text ROAMING to 150 to make sure you're all set up to use your phone abroad.
Have an amazing time 🙂
6 REPLIES 6
@Marka2723  Text RO Canada to 150.  You’ll get back a message with prices and links to purchase add ons
Solution
Hi there @Marka2723
Thanks @Chris_B
@Leanne_T, Thank you for the advice love, it was only £10 to change my plan for a month to the max plan which will save me a couple of hundred quid at least xxx
by Ace Contributor
Why doesn't the Go Further add-on get listed when you search for countries?
I'm not sure, @chistery. It's maybe because it depends which plan you're on, as to whether it's appropriate to offer it.
I'll feed this back to see if/where it is appropriate to offer it on the roaming tool. 🙂
