by marygalla8 Investigator
Anyone else having problems gifting data
Anyone else having problems with gifting family data
by Ace Contributor
Re: Anyone else having problems gifting data
Hi @marygalla8
Can you please explain what issue you facing during data gifting?
Ee Problem says they are having problems try again later.
Hi there @marygalla8
Is this now working for you?
If not, do you get an error message?
Leanne 🙂
No not working getting an error message
Hi @marygalla8
What error message are you getting?
