Highlighted
Add to Plan not working
Is there a current fault with the add to plan page? It directs me to ee.co.uk/unsupportedpage - Ive been with EE for 6 years. So not a new customer related issue.
A message displays "SORRY! We couldn't find that page."
Highlighted
by Ace Contributor
Solution
Re: Add to Plan not working
Hi @JakeAH
Welcome to the EE Community,
If you contact freephone 0800 956 6000 opt 2 opt 1 a sales advisor will be able to process your add to plan order.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Hi @JakeAH
Thanks,
David.
