by Tanyam1986
New Member
Upgrade to s20+ 5g
I want to upgrade to the s20+ 5g however my area does not yet have 5g coverage. Will I still get 4g coverage or will I end up with no signal and a phone I am unable to use?
Solution
Re: Upgrade to s20+ 5g
Hi @Tanyam1986
Your device will work just fine. I'm doing the same as you as I don't have 5G yet, and where I live coverage is limited to certain areas for now.
Solution
Hi @Tanyam1986
Recent solutions
