Highlighted
by Skilled Contributor
Skilled Contributor
Security
wats the best security for ur phone
Highlighted
by Established Contributor
Solution
Re: Security
The best security is you...
  • Don't get sucked in by scams.
  • Don't use third party app stores
  • Don't install any security apps or virus scanners from Google Play or anywhere else - they're just snake oil and slow your phone down.
  • Use a password manager and enable 2FA on every website or app that supports it.
  • Watch where you click (or tap!)
Highlighted
Re: Security
@moulinrouge234   look at the most popular in the play store.
if you mean anything else don’t use links to open an account in a email as these are probably going to be a scam.
Highlighted
Re: Security
Morning @moulinrouge234
Thanks for posting on the community.
You can also find some great advice and help with scams and staying safe in our Scams: Information about scams currently circulating post.
Thanks.
Highlighted
Solution
Re: Security
Highlighted
Skilled Contributor
Re: Security
Thanks think ive wrecked my phone will need to factory clean it change all
passwords and get advice wait till ive woke up with more coffee
Recent solutions
