by imran619 Contributor
Question regarding 5G Data SIM Usage with a 5G Router
I wanted to know as per 3rd Party websites who sell 5G Routers. They all recommend EE 5G SIM Data Contract SIMS. I wanted to know is there any caps on the SIM's even though they are Unlimited Data.
Solution
Re: Question regarding 5G Data SIM Usage with a 5G Router
Both our personal and business unlimited data plans come with a fair usage policy of 1000GB, @imran619.
8 REPLIES 8
@imran619   If you tether more than 12 devices you’ll be classed as a business user and you might find you’ll be put on a different tariff.
and EE will consider usage above 1000GB/month to be commercial use and have the right to move you to a business plan.
Ok thats confusing as i was told about the 1TB limit on the business plan? Hence i canceled it?? As i previously contacted EE earlier today who advised i can use the data SIM with a compatible 5G Router with no mention of caps. When i then purchased it and went through credit checks the customer service rep advised there is a 1TB fair usage policy and a cap at 120GB if used with a router. So i am now confused.
1TB nowadays is nothing with a household with multiple devices and streaming 24/7 i currently hit 900GB/1TB monthly.
Hi @imran619
The 120GB is the data sharing limit I believe (sharing data with other Sims on your account). The 1000GB limit is fair use before EE would consider you a business user. In reality I don't know how strict EE are on this limit, so if you exceed it one for example.
1TB for home use is a massive amount of data even for the most data hungry family, if you are using 900GB/1TB then you need a more commercial option.
There is no such cap. EE can't stop you putting the SIM in any device you choose & can't make extra conditions if you do so, as per OFCOM Regs.
Maybe they were confused with the FUP of 12 or more devices serviced by the router & its SIM being considered as business use.
Got you. So for a business/commercial SIM package there isnt a real cap or 1 TB fair usage? Correct me if I'm wrong
Hi @imran619
Welcome to the community. 🙂
With the EE Business Unlimited Data plan, we consider any mobile data usage above 1000GB to be inappropriate, and reserve the right to move affected customers off an EE Business Unlimited Data plan.
Ok now I'm receiving mixed messages on this post.
Solution
