Highlighted
by Skilled Contributor
Skilled Contributor
Newcastle 5g
Newcastle rang ee and got through to them only an network can redirect the calls or special forces
Read more
Was i to put it on 4g3g2g when i have 5g phone wont ring someti.es and poor signal sort it out ee
Highlighted
Skilled Contributor
Solution
Newcastle
xxx.xxxxx@ee.co.uk said i had 42 days to cancel contract gave me a link to download to reset
 Said buy me a coffee or die or help him just to let u know if i die we all die
[mod edit: removed employee's surname]
Highlighted
Skilled Contributor
Solution
Newcastle
Highlighted
by Ace Contributor
Re: Newcastle
@moulinrouge234Please edit your post to remove personal contact details.
Also, do you actually have a question?
Highlighted
by Ace Contributor
Re: Newcastle 5g
What is your question?
Highlighted
Re: Newcastle 5g
Hi @moulinrouge234
Have you checked EE Network Status Checker?
EE are still rolling out 5G so the service will improve. Your device should automatically attach to the strongest signal.
Highlighted
Skilled Contributor
Viruses
Its the icognito app that says buy me a coffee or let him die or help him the app with the black hat speek soon
Recent solutions
